uphiller said:
For that reason, I think 16" is possible, especially with an internally geared rear hub.
You may have just added a big problem to the mix. I don't know of any IGH that is wider than 135 mm. Also, I'm pretty sure the Alfine uses a very narrow chainline, which means your front chainring is very close to the tire even with a 73 mm shell, leaving very little room for chainstays - especially short ones. And since you keep mentioning trials riding, have you tried an IGH for trials?
uphiller said:
The reason such short stays are desirable is that they make the front end easy to lift. The same can be accomplished with other means- a slack head angle by default puts the rider's weight behind the front axle, making the front end easy to lift.
Just think of it- the jumpability of a 26" wheeled bike, plus the rollability of a 29" wheeled one. It's something worth a pound or more of extra frame weight, in my view.
I'm not really sure what your objective is by going really short. Lofting the front? Raising the bottom bracket will do that as well...with other consequences.
I'll tell ya what...For the longest time, I hated 29ers. All the normal production bikes were extremely boring to ride. They felt dead. Couldn't manual, couldn't bunnyhop, and couldn't whip in the air. Just some of my background, I race DH, 4X, and BMX. I ride XC like I'm riding any one of those bikes. I built my 29er SS with 16-5/8" stays, and I've been surprisingly quite happy with it. My opinions of 29ers changed. I go back and forth between this bike my Black Market Mob (with the wheel slammed forward) and my 20" and 24" BMX race bikes (the dropouts on the Intense Podium 24 are filed to allow the wheel to be even further slammed forward). As odd as it sounds, I can get the front end of that 29er up easier than the other bikes. Most of this may also be due to the taller front end. I'm just saying this as you may be chasing something that you may not need or want. Try a 29er with around 16.5" CS that is set up for you and you may be surprised.
Although I haven't taken my 29er to the BMX track, I do take my Mob there often. And when manualing and tucking over larger whoops and tables, my butt often hits the back wheel. I'm sure it would be way worse with a 29er! So bad that I think that when my butt hits, it would buck me forward. Some day, though, I will regear it and try it.
