Mine do. And I have even more extra pins in a parts drawer if I want to change it even more.Why not both?
Got to disagree with you, more pins cause more float and less contact with your platform. Wider spaced and fewer pins will dig deeper into your shoes. A rudimentary visual is the bed of nails magician illusion. More nails equals more surface space to distribute your weight across.If you have around 10 pins per side, 1mm longer pins - will make a big difference.
If you only have 7 pins per side, 1mm more will make a slight difference.
'Born to ride!'
Yeah, I figured that would fly over your head.A bed of nails vs 10 contact points!?
Good luck w/ those BON pedals ;-P
'Born to ride!'
A simple pressure illustration:1, 2, 3, 4, 5, 6, 7, 8, 9...
10!!!
'Born to ride!'
While what you say is true, it's not the whole answer. Grip on a pedal isn't entirely about pin penetration into the shoe, but also requires consideration of the fore/aft grip and the side/side grip. Pin shape and pin arrangement also play roles. As in my DMR Vaults, the arrangement of the pins creates a bit of a concavity on an otherwise flat pedal body, which affects the fore/aft grip in particular. Other pedals do similar.A simple pressure illustration:
My contention is with your statement of 7 pins with a height increase of 1mm will have less of an impact on grip when the reverse is true. Less pins in a pedal will cause the sole of your shoe to deform more thus causing deeper penetration into its surface granting you more grip. If you flipped your 10 pins vs 7 pins arguement then what you said would be true. But thanks for sharing Sam Hill is all of his awesomeness.
P.S. I am glad you presumably still have all of your fingers![]()
