Short chainstay DJ that will fit a 27.5 wheel?
3582 Views 39 Replies 11 Participants Last post by  OldSchoolMBer
Looking at something like the Shonky, prefer sliding drops.
I'm curious if any of these 26" framed DJ's have enough room to fit a bigger wheel.
Anyone?
1 - 20 of 40 Posts
Run vee tire crown gem with your 27.5. They have low profile sidewall
If you find a bike with really long horizontal dropouts, you might be able to slide the wheel back far enough to fit a 27.5. Just remember to get a long chain.
New project Ben?
Sorta, just trying to find something that doesn't exist without going custom ;)
The N9 is probably not gonna work for my needs, it's just too long for a pump track bike.
I got my eye on the Why Cycles TF, but it's pricey and might be hard to offload if I change my mind down the road..
Did you try running it in the shortest stay position? Why cycles is definitely intriguing, but why not check out Chromag? They make all sorts of hardtails including a 27.5.
A DJ has a much shorter reach than a trail bike, I want something with a 415ish reach and shoas possible chainstays.
The Why looks very nice, but $$ for a frame only.
It would be easier to get a 26 DJ, but I want a really slack HTA like a 4x bike.
You’re aware that the Nimble 9 chainstays are already 415-430mm right? You could get a small frame. Those are 425mm reach.
Ahh, 4x bikes. Still the only Yeti I want.
Like these?
One is a plain old NS frame. Not sure if there is stock anywhere though.
The Enduro SX and the Yeti 4x bring me back.. aahhh....
Have you looked at NS bikes? I looked at them a while back and I think it's the Surge that's a 26/27.5. Only bike I know off hand that's listed that way
  • Like
Reactions: 1
A small Chromag Stylus has a reach of 418mm and 419mm stays.
A small Ragly Mmmbop has a reach of 420mm and 425mm stays.
Guessing you're in niche territory where you can either double-downsize a 27.5 HT or maybe cram in a 27.5 wheel in a DJ franken-build. Might be interesting. Might flame out.
  • Like
Reactions: 1
Why 27.5 on a DJ bike?
Because it's the type of thing Ben does.
  • Like
Reactions: 1
It’s Tuesday… Ben needs a new bike. :)
  • Like
Reactions: 3
Nothing wrong with a new bike, but a big-wheel DJ bike? Blecchhhhh!!!!
  • Like
Reactions: 1
Except with Ben's bikes, they must be something completely out of spec and completely unrealistic. And a 27.5 DJ is perfect for this :)
  • Love
  • Haha
Reactions: 2
Just looked up the specs on the NS Surge EVO (Large)
HA 65.5 degrees
CS, sliding dropouts down to 411mm
Reach 409mm
26x2.6/27.5×2.4 compatible
  • Like
Reactions: 3
HA 65.5 degrees
Reach 409mm
Yup, but the specs are for the bike set up with a 160mm fork, so reach would be a little longer, BB a little lower, STA/HTA steeper by 1.5 degrees with a 120mm fork.
It's one I have my eye on for sure .... the frame is not expensive and it's available, just need to build a 135mm spaced rear hub.
The 27.5 tire clearance is kinda worrisome as I'd like to run 2.5-2.6, also gotta buy sight unseen.
1 - 20 of 40 Posts
