This is where everyone lists the shoe that they are currently wearing and like, even though it may not fit you...
...mine is the Specialized BG Comp.
Those do look nice & priced reasonable, thanks.idaz said:Shimano MO86. Realtively cheap,$100-110. The good kind of rubber sole for hike-a-bike and plenty stiff.
Matt
Sweet an Monkeybutt approved item!AKA Monkeybutt said:TRB, I just picked up some 086's. I have two rides on them and they feel great. Like said above, a good rubber bottom for the rocky stuff, light and seem to vent good. check if Performance in Scottsdale has them in your size and go try them on. I give them a :thumbsup:
Need some info; about your feet, are they flat, do you have high arches? Do you have wide or narrow feet? are your feet wide or narrow in the ball/fore foot? wide or narrow heels? Do you prefer lace up, velcro strap, or velcro with ratchet buckles?trb2929 said:I've been wearing the Lake M165 for a couple years now and it is time to replace them. What's the new shoe to have these days and why? Looking at the Pearl Izumi Attack II or just replacing with another set of Lake.
Size 44 in LakesAzSpeedfreek said:Need some info; about your feet, are they flat, do you have high arches? Do you have wide or narrow feet? are your feet wide or narrow in the ball/fore foot? wide or narrow heels? Do you prefer lace up, velcro strap, or velcro with ratchet buckles?
Shimano will probably work well for you as well as Pearl Izumi. One thing I found with the Pearl shoes that are more comfortable to walk/hike in is that the cleat is off set to the inside quite a bit to the poing the outside of your foot could feel very unsuported! Specialized might work for you but they tend to have a high arch that can bother flater feet. Sidi, they aren't as durable as they used to be and they don't fit the same as they once did.trb2929 said:Performace has been out of size 44 for a month. :nonod:
I was looking at the 076s, specifically cause they do not have the buckle.AKA Monkeybutt said:TRB, I just picked up some 086's. I have two rides on them and they feel great. Like said above, a good rubber bottom for the rocky stuff, light and seem to vent good. check if Performance in Scottsdale has them in your size and go try them on. I give them a :thumbsup:
I ordered a pair of the Shimano MO86 from Performance since no local shops had the 44 in stock. Arrived a day early compared to what tracking stated. Look nice and I'll have to check but I bet close to a pound less in weight compared to the Lakes. Need to hit Rage for some new Time cleats and I'll be ready to ride. I guess I have wide feet as I just catch the last two notches in the ratchet strap. This is with normal white socks so maybe with some stretching and thinner socks I'll catch a couple more. Only issue I see at this point is the ratchet setup. Might end up working and lasting well. But if that strap snaps you're going to be finishing the ride with a sloppy shoe for sure.trb2929 said:Performace has been out of size 44 for a month. :nonod:
My Shimano shoes have been great, had to retire set #1 after 2.5 years, sole bald, coming off. This applies only to the SH-M225 model. In the previous decade experience running Sidi's, they usually separate at the toe pretty quick, but shoegoo takes care of that about 3x per yearEvil Patrick said:Tracey had a new pair of Shitmano's
Mainly because I wanted to try something different. I might end up regretting buying the MO86! I'll give them a try for now and if I don't like them I guess I'll have some back-up shoes.ionsmuse said:The MX165's are really good shoes. Why change?
They're not quite as stiff as my Specialized Carbons were, but they hike much better and are comfier.
