I've got a 2014 Devinci Dixon. It came with the newer Fox 5 piece hardware, but the upper rocker bolt would loosen and begin to creak after 2 or 3 rides with proper torque and liberal application of loctite on the rocker bolt threads.
I decided to try out the RWS needle bearing kit as a replacement. I emailed Real World Cycling and they recommend the 41.15mm kit. I recently learned, however, that the upper eyelet requires a 42.2mm spacing.
I've been running the RWS kit for 5 months or so of heavy riding, and I haven't noticed any issues. The bolt remains quiet and doesn't loosen, however, I'm slightly concerned about the loss of 1mm of reducer width between the rocker and what long term effects this might have on the frame or life of the rocker bearings.
Is 1mm something I should be losing sleep over in this case?
