1 - 3 of 3 Posts
How do you keep air from escaping when removing shock pump from the valve?:madman:
I thought that the air I hear escaping was only coming from inside the pump, but when I reattach the pump the pressure is lower.
When you detach the hose, you release the air that is in the hose etc,
When you reattach the hose the shock air repressurises it.
So when you detach the hose the shock is at the pressure indicated on the gauge, when you reattach you loose some pressure repressurising the gauge.
1 - 3 of 3 Posts
