1 - 3 of 3 Posts
mtbr "member"
Any air shock that's 7.5 x2.
rokklym said:
What are the options for Air shocks for an AC2? I'd like to get some lighter weight parts for it to make it more trail worthy.
You just need a 7.5 eye to eye air shock with a 2 inch stroke. I'd say Swinger SPV would do well. Or a Fox with propedal. That should help you lighten up and still pedal in the 6.3" mode.
I'm running my stock coil Swinger with the SPV chamber pretty much at 150 psi. It helps me climb better - not as good as my 03 Dakar XLT with it's Swinger but that's mostly due to the AC's slacker headtube angle.
REEK
Banned
Air Shock Option
I'm thinking of getting a 5th Element Air for mine. You need the 7.5 x 2.0 version and two mounting kits as the stock mount hardware won't work for this. It's listed at approx. 199 grams. That's much less than half the weight of my Swinger 4-way w/ 550lb coil.
1 - 3 of 3 Posts
