Depending on what hardware you have you may want to swap over to the Fox polymer IGUS bushings as they are a bit easier to swap from one shock to the next in my experience.
The metal type bushings can be pressed out via various methods and the variable there is your patience and the tools you have on hand.
That assumes that your Fox shock doesn't have bushings in it already.
Example of metal bushings:
This style (above) takes your hardware from your frame and goes inside the bushing (will look like items 2 and 4 below basically).
Fox polymer style:
1 - replaces metal bushings
2 - goes inside of 1
3 - goes in the outer lip of 1 and over the end of 2
4 - goes on last to 2
Might be too much info, sorry about that. Didn't want to get a half-assed or quarter-assed answer.
