1 - 4 of 4 Posts
· Registered
Got CC Kitsuma. Front bushing is too short for Nomad frame so I've replaced bushing with original one which was in the RockShox OEM shock. Also I've needed to use 0,5 mm shims because of small gap between original spacers and the frame. Is this construction seems ok to You or should I wait for original ones from manufacturer?
· Registered
Discussion Starter · #3 · (Edited)
If the shim brings the spacers flush with the thru-pin, that should be fine. I would put the shim on the outside of the spacer.
Outside You say? Ok, maybe it's good idea, Thanx dude. Yeah, shims seems to be ok, cuz it is the same diameter as a bushing axle. I made shims in correct thickness with file tool:)
1 - 4 of 4 Posts
