Got a question for you knowledgable Turner riders out there...
I'm riding on a 2010 DW Spot with a RP23. I thought I had the shock dialed at 175 psi. Felt nice and plush, but still didn't bottom out. I'm 205lbs geared up.
The last couple of rides on the Spot the rear has felt very "stiff". The best way I can describe the "stiff" I am talking about is...it's as if you started the ride with Pro Pedal off and then you turned it on to number 3 mid way through.
Thought maybe I had overtensioned a bolt... So I loosned and retensioned all the bolts for the rear triangle with a torque wrench. Didn't help.
I took it to a shop here in Colorado Springs. They are a Fox retailer and service center. They said my RP23 had the slowest damping they had ever seen. Which my response was that is how DT ordered them from Fox so that they work best with the DW link(am I wrong about this?) There is no Turner dealer here in the Springs so this shop is my best bet. They took apart the shock and said everything looked fine (seals are good, oil level is fine)
Sooo at this point, if I set the shock with the correct sag it still feels harsh. If I want plush I have to drop the PSI significantly and then I start bottoming out...
Any suggestions?
Any suggestions?
