RC JonB said:
I have a zen that I purchased off of eBay --- it's been working just fine and I love it, but since 5th element is no longer in business, my question is this: how easy is it to drop a new, say, fox float or other shock into the frame? I think it's a 6.5"x1.5" shock, so does all of the other mounting hardware work in every shock?
Thanks.
It you have a 5th Air the mounting hardware will not fit. It uses Spherical ball joints that are unique to the 5th Air instead of standard DU bushings like most shocks.
Most other brands are compatible with each other. Fox, Marzocchi, 5th Coil, Newer Rock Shox (Monarch,Vivid) all use 1/2 inch (12.7mm) hardware.
Manitou and older Rock Shox use 12 mm, and are not compatible with those above.
With the proper mounting hardware I would think most 6.5X1.5 shocks should be an easy swap.
I'm not sure of the exact size (width,bolt size) needed for the Zen though.
Hopefully someone from MC will chime in with that info.
Hope this helps.
BTW: The only reason I know this is because I've been through it before.:madman:
I have a 5th Coil with Marzocchi hardware and a RS Monarch with Fox hardware.
