I have a Trance X3 (09) model. It's my first duallie, is standard and has approx travel of 125-130mm (as advertised). It weighs about 12.2 - 12.5 kgs.
I weigh 66.5 kgs + pack (maybe 5) and water bottle/tools (maybe 2). So total 73.5 approx.
It has Mavic 117 rims, Kenda Nevegal tyres with standard tubes and tyre liners.
The fork is Fox F-Series R 32mm.
The bike shop set up the fork with (I think 130 psi, can't recall sag). It was way too hard.
The shock is Fox Float R. Lbs setup was 8mm sag and approx 150 psi. It was not too bad.
The hills I run here are steep, rocky and have a lot of steps, some tree roots, sharp cambered corners, etc. (Good tracks but rocky).
The front end was always bouncing off rocks putting me off line. The rear seemed ok.
I currently have the fork set at 85 psi, approx 25mm sag and on the fastest rebound speed setting.
The shock is at 140 psi, 12-15mm sag and fastest rebound setting.
Tyre pressure is 24-26 front and 26-28 rear.
The front end is now handling much better than it was, not so much bouncing now.
I'm considering letting more air from the forks (maybe down to 75psi) but am unsure whether it's a good way to go.
I'd been told by an experienced rider that the fork should be approximately 140 -150 psi.
The fork doesn't seem to have bottomed out yet.
Today I'm going to try 75 psi but would still be interested in opinions and advice from experienced (which I'm not) riders. I'm not fast yet either but am aiming to be given some time.
Which is the correct way to go here?
P.s. I'd like to lower the rear shock pressure too but it is almost using full travel I think. Should they bottom out at all or only by accident (bit hit on unseen obstacle)?
