1 - 13 of 13 Posts
EDIT: Shimano is warrantying. It's caused by a fragile + broken spring that tensions the pawl.
My 7-month old shifter (XT M8100) randomly stopped shifting up the cassette. I took it apart and cleaned out the grit, but it looks like the pawl has no tension to engage the ratchet. What normally keeps the pawl under tension? And is there a way to fix this?
Pawl not engaging ratchet unless it randomly falls into place:
Hand Finger Nail Thumb Bicycle part
Out spokin'
In cog? Neato!
That happened to mine after about 11 months of use. It took the LBS about 4 months to get a warranty replacement for it from Shimano. In the meantime, I switched my shifter and derailleur to Sram. ?‍♂
Please send me your warranty replacement Shimano shifter. PM me and I'll give you my mailing address. Thx!
=sParty
Mine broke while on a trip in CO. Luckily found a local shop with an SLX in stock. When I got home I sent the XT into Shimano and received a replacement along with cable and housing within a week. Hopefully the new one has an updated spring that doesn't break. It's funny, I passed on getting AXS as I was concerned about reliability....lol.
BOOM goes the dynamite!
Interesting. I'd pass on AXS because we have sticks and rocks on the ground around here and a replacement RD is $$$.
Discussion Starter · #8 ·
Just to conclude, the pawl engages the ratchet through a tiny wire spring. This spring has a single wire that goes over the top of the pawl for tension, but that wire broke off. This seems to be the same issue that others are facing in the above linked XTR thread.
My LBS called Shimano and they'll be sending an XTR shifter as a free upgrade. So the bad news is I'm getting a shifter that may also be prone to failure. The good news is Shimano is diligent with their warranty, and XTRs include a 3-year warranty (compared to XT's 2-year warranty). The new shifter should arrive in 2 - 3 days.
Discussion Starter · #11 · (Edited)
XTR here, same issue I assume?
Yes, likely the same issue as mine. It won't shift/click unless the pawl randomly falls into the ratchet teeth (you can try to force this by jostling the shifter) or if you're in the smallest 3 cogs. In the latter case, the pawl (circled) can push against the "wall" (straight line) to shift without engaging the ratchet.
Hand Fluid Gesture Finger Thumb
1 - 13 of 13 Posts
