This is a ~1 year old M8100 XT 12 speed rear derailer, with about 1,880 miles on it (thanks Strava).
So a couple of weeks ago, the clutch mechanism seized up. The band was bone dry, so I reapplied some fresh grease and now it works great. EXCEPT....
The lever that activates the clutch will not stay in the 'on' position. I've taken it apart several times, tried every possible position, looked up assembly manuals and verified that I'm assembling it the right way. But still, nada.
Normally when you flip the lever all the way to the on position, it gets into a zone where theres no more tension, so it sort of locks into place. But mine no longer does that. It's continuous pressure on the lever. So after literally less than 5 minutes of riding, the lever completely pushes itself back to the open position. I've looked and looked and I cannot figure out what is going on for the life of me. Hopefully someone here can see something wrong?
I took a pic with the lever in the on position, the off position, and a little video of me flipping the lever. You can't really "see" the tension on the lever, but you can kind of see the way it doesn't kind of 'snap' into locked position.
