Hi,
I am installing a MT-8100 Crankset on a Santa Cruz hightower with 73mm threaded BB. This should mean that the 2.5mm spacer should go on the driveside, right? Installing like this gives me an messuared chainline on approx 54,5mm, without ut approx 52mm. Also the spacer makes the chain grind the chain guide (which it did not do before).
I moved the spacer to the none driveside (where it should be, right?) and have no chain rub on the guide and the chainline looks good. Can this cause any issues?
