1 - 7 of 7 Posts
Hello,
I am fixing up an old Trek bike circa 1996 and I am having some trouble with the Shimano ST-MC12 shifter. It has a hex bolt on the bottom that is loose and I cannot figure out how to tighten it. Since it is loose, shifting can be erratic.
Any help is greatly appreciated.
There's no app for this.
confused...
What bolt, where, and what does it do?
Also, if it's a standard Hex bolt, just insert the correct size key and tighten it.
Lastly, it's an old part, it might simply need to be replaced.
Jim
Discussion Starter · #3 ·
It is a hex bolt located on the bottom of the shifter. The shifter in question is the one near the bottom of the picture you posted. I am going to assume it holds the whole assembly together.
I tried to tighten it conventionally (clockwise), but that does nothing, it just keeps turning and turning.
I had this happen with some old shifters. The pawl/ratchet system inside loosened or wore down (plastic pieces). I had to push upwards on the lever with my thumb when shifting in order for it to engage. My solution was some nicer, more recent LX shifters.
You'd do the same as
you would with any bolt/nut that is stripped: it's not repairable, so replace it, as the other poster coz22 said.
Jim
.....also
I'm also resurrecting an older bike (94 GT) with MC 12........would like to replace them completely. My question is- what would be compatible and how difficult is it to replace shifter, cables AND adjust cables/derailer etc. I'm kinda new and every bike shop in town seems to think it to be too difficult to attempt.....hence the challenge. What do y'all think? HELP
thoughts...
OK, so those older brake/shifter things are for 7 speeds. here's what I suggest, you'll have to figure out the cost:
Get a new 9 speed drive train, LX is fine. You'll need 1/2 a new bike in parts though: http://www.performancebike.com/shop/sizecharts/howtoupgradeshimano.cfm
or, hunt around for 7 speed shifters on the Internet, or some low end dept store bikes are seven speed, you might be able to pirate some parts for a dept store.
Plan C: buy new 7 speed shifters: http://www.cyclepath.ca/products/item3266.htm for $14 + shipping, and add new brake levers from your LBS or mail order like these for $26 + shipping: http://www.universalcycles.com/shopping/product_details.php?id=2157&category=349 Take the whole pile to LBS and have them install it all for I dunno, $50?
Plan D" new bike.
Hope that helps, Jim
1 - 7 of 7 Posts
