First Impressions: Technical Data and Installation Issues
If you just want to know what it's like to ride one, skip forward to the next message. I'll update this thread as I get more riding time, so keep checking back.
I just got my 29" rigid bike set up with a Shimano Nexus 8 "Red Band" gearhub, SG-8R25-VS, with no rollerbrake. This is the premium level gearhub that is purportedly rated for off-road use: it is distinguishable from the regular version only by a small red band next to the drive side hub flange. GT uses this hub for an internal transmission on their iT1.
Sheldon Brown's website (http://www.sheldonbrown.com/harris/shimano-nexus.html) has a lot of good information about this hub, and makes good background reading. However, it is out of date in a couple respects, which I'll note throughout the review.
Claimed weight is 1550g. The bike shop scale showed 1590g without the rear sprocket or axle nuts, but with the rear axle. It only comes in 36H. There is a black version available in Europe, but I was unable to get anything but silver here in the USA.
The 305% gear range is roughly equivalent to a 1x9 with an 11-34 cassette. Sheldon's website claims only a twist shifter is available: this is wrong. You can also get a two-button shifter/brake lever: each thumb button moves one gear up or down at a time. There is no independent button shifter, so if you want to run hydros you'll need to run the twist shifter. The shifters are not compatible with anything else: SRAM ESP 8-speed shifters pull just about the right total amount of cable, but the Nexus shifter has exactly equal cable pull between gears and derailleur shifters don't.
Installation is tricky, especially if you or your shop hasn't done it before. The hub is 130mm OLD, so to use it on a standard 135mm MTB frame you'll have to add spacing washers, or do a funky trick with the non-turn washers. "What are non-turn washers?" you ask. They're little metal bits that sit in the dropouts and keep the axle from spinning. Shimano provides three pairs of them for different angles of slotted horizontal dropouts, but if you have vertical dropouts, you'll need to order the appropriate pair separately.
And then comes the funky bit. The approved method of assembly is for the non-turn washers to go on the outside of the dropouts. Well, if you don't have or don't want to find spacing washers, you can use two of the same washer (instead of one R and one L) and flip one so it goes inside the dropouts, then dish the wheel slightly to keep it centered. I think you have to do it this way, with the hub slightly offset to the non-drive side, if you want to run a rear disc brake -- but I can't yet verify this.
This took about a week for the local bike shop to figure out. But finally it was done, and I had a rigid 29er with an internal gearhub.
My bike now weighs between 2 and 2.5 pounds more than it did as a singlespeed: bathroom scale weights aren't exact, even if they are the nice doctor's kind with the sliding weights. This is less than a pound heavier than going 1x9 with LX.
Now you might say "The Nexus doesn't allow a disc brake, just those crappy Rollerbrakes that weigh three pounds, make it impossible to fix flats, and don't actually stop." Not quite. You can get a disc adapter here: http://shop.cnc-bike.de/catalog/product_info.php?products_id=988, and possibly from Cannondale, who make one for this bike: http://gb.cannondale.com/bikes/06/ce/model-6BR1.html
But I am running V-brakes right now and have not tested either of these.
Next installment: I ride it.
