1 - 3 of 3 Posts
I sure could use some help here....my LBS was not able to figure this one out.
I have a screaming yellow 03 stumpy, i replaced the original crank set, cassette and chain at the same time with the new XT stuff. I have a intermitant chain slip problem when I shift into the second to the largest ring on my cassette, it doesnt matter if im in my small or middle ring on my crank...the chain seems to not want to get on that ring...
My LBS reversed the spacing on my spacers on my bottom bracket. this seemed to help very little. Has any one else had this problem upgrading to the new XT stuff? Any suggestions or ideas would be greatly appreciated.
sadly, like the element
Problems would most likely be,
worn chainring (you say it's new though)
worn chain (same, new)
improperly adjusted front deraileur
I'm going with improperly adjusted front deraileur, but I'm not a professional mechanic so I could be completely wrong. They should not have had to adjust the spacing on the crankset though, just the front deraileur needed to be moved out.
I had the same thing when I installed my 11-34 XT cassette. I think I just tightened the adjustment barrel on my shifter. You could also try to tighten your B-screw if you're going from a 11-32 to a 11-34.
1 - 3 of 3 Posts
