As the title says, my rear Shimano M615 caliper failed this past Saturday. I was having to pump my brakes a lot before rides to get it firm - then I realized one of the pistons was stuck. I dislodged it, but then it started leaking. I had to use some regular mineral oil to get back but now I�m afraid I may have voided the warranty.
Since my bike is a 2017 and I believe the warranty is close to done anyway, I�m just going to replace the caliper. Thing is, not sure if I want to replace with the same one or upgrade to a SLX caliper or M6000 caliper. The performance was fine when they worked, I just don�t want to replace it with the same caliper and have more issues if they�re problematic. Should I just -
I�d like to same some cash and keep what I got working, but I don�t want to have nagging issues in the future. Also, not sure about compatibility since SLX/XT use banjo bolts and mine does not.
- Replace with same/similar M6000 caliper?
- Replace bad caliper with one new SLX caliper?
- Replace both calipers and levers with an upgraded SLX set f/r
