1 - 8 of 8 Posts
· Premium Member
I’ve noticed that my Rise M20 has developed a bit of a front wheel vibration under braking. I have only ridden the Rise on some very easy bike rails, nothing that would have over taxed the frame or fork.
It’s a new bike that I had my LBS put together so I don’t think there is any issue with assembly.
Any insights would be appreciated.
· Registered
Possible glazed pads? Pull the pads - check their condition
Are your rotors vented? I have had a pulse feeling with vented rotors (holes in brake track) where I think it was the leading edge of the pad "catching" the vent holes. I minimized it by sanding a chamfer on the leading edge of the brake pad as well as chamfering each hole on the brake track.
· Registered
My Trance-E came with the same brakes and had the same vibrations on the front brake.
Switched to full sinter pads and the virbration became less, but it's still there.
I think it's the rotor. The first generation of TRP rotors were even worse. I had those too.
Replacing the rotors fixed the problem for me.
I'm not saying that the design of the rotors is at fault, but maybe a manufacturing qc issue were the rotor is not made evenly around the surface. A friend of mine had Magura SL rotors that were also terrible with noise and vibrations.
Same story, nothing helped except replacing the rotors.
· Premium Member
Discussion Starter · #6 ·
Thanks all for the feedback.
It doesn’t particularly bother nor does it seem to cause any braking issues other than those described but I just don’t want the front brakes to suddenly stop working or have a some sort of wheel issue.
I’ll have to take it into the shop
1 - 8 of 8 Posts
