No, not a silly question at all. A thousand miles on (assumed resin pads) is good going so I'd treat yourself to a new set and keep hold of the old ones as spares just in case.
A bleed kit is an essential addition to your toolbox and well worth owning if you have hydraulic brakes anyway.
Your right, your brakes have reach adjust, not bite point adjust. If you're happy with the lever blade's resting position then don't bother with that adjustment.
A proper bleed and optional new pads should have your brakes feeling like new again. If by the very slight chance there is another issue causing this a bleed would be the first thing to do regardless given the symptoms you describe. 😉
