I just got my 160mm Shimano adapters to install my calipers. My rear caliper installed fine but the front one doesn't install correctly. There is a arrow on the side of the adapter showing which side to install up. In the proper install the caliper is to far from the rotor. If I turn the adapter down (up arrow pointing down) Look at picture. It appears to install correctly. I just bought the adapters from Icycles and there is no markings for front ar rear. Should I just run these like this anyone know if there is a different adapter I should use.
