I am getting an sx trail on Thursday (woo!), which comes with Truvativ Hussefelt w/ BlackSpire Stinger shift guide. I also have a set of the Hone Hollowtechs (dual ring version) sitting on my Kona Dawg Deluxe. I'm going to be getting rid of the Kona once the new bike arrives. Anyway, as you've probably already worked out, I'm thinking of using the Hone's on the sx; as I've read that the Truvativ likes to work its way loose. I also had the same problem with the original Truvativ cranks that came on the Dawg, hence the reason for me buying the Hones in the first place! I will be riding downhill, trails, freeride: basically, anything I have the balls to do.
So from this a couple of questions arise:
Will the Hones fit on the sx and vica versa? The Kona Tech website says the dawg De: 68X113mm, whilst the sx, going by Rutland: BOTTOM BRACKET Truvativ Howitzer Team, outboard bearing, 51mm chainline, 73mm shell.
If it will fit, will the BlackSpire Stinger work with the hones?
Respective websites:
http://www.rutlandcycling.com/8009/Specialized-Bikes-2008--SX---Trail--FSR-I-Mountain-Bike.html
http://www.konaworld.uk.com/kona2u/2006tech/Catalogueframedetails.xls
Much Love
Hazy
Much Love
Hazy
