i found a set of these cranks i can get cheap_new-never used comes with a 4 bolt spider. I think it might work well for a singlespeed set up. So those in the know, is there an aftermarket spider i can run to use Spot or Boone chainrings? Any alternative to the Shimano M-952 Bottom Bracket? anything i should consider if i run this setup?
Thanks.
Thanks.
