Not sure. You can check the manual here see if that helps (assuming this is what you are talking about) Shimano ST-M761 Tuas Perpindahan/Rem Exploded View | Manualzz
You probably have i-spec shifter (you should check exact model of shifter to see which i-spec version you have).Can I separate the shifter from the brake lever? I would like to buy another brake system and it has its own levers but I will still need the shifter part. Is this possible, need help, Happy Holidays
I am buying the Piccola Carbon brakes from Germany. Yes I figured that out the I-spec is what I have. ThanksYou probably have i-spec shifter (you should check exact model of shifter to see which i-spec version you have).
New brakes can probably be fitted with adapter for i-spec. Which new brakes model are you buying?
There are a few I-Spec designs (Thanks ShimanoI-spec is what I have.
