Zanetti said:
The rapid-failure (sorry - couldn't resist), ahem, rapid-fire shifters were never intended to be user servicable. When they croak, Shimano wants you to buy a new set. Service parts and information aren't available.
Oops, what are these then?
Yes, not all the parts are available, and they aren't intended to be taken apart and put back together. It's kind of like a 3 speed hub, it can be taken apart and put back together, but you better remember what order you took out the parts in, so you get them back in correctly.
LD8508
16
STM800/760-5 Left Hand Release Lever & Fixing Bolt Saint M800; XT M760,765
LD8509
29
STM800 STM760/5 Shifting Cable Adjusting Bolt Saint M800; XT M760,765
LD8499
12
STM800/765/760 Right Hand Lever Cap & Fixing Screw Saint M800/XT M760/M765
LD8500
23
XT ST-M760/5 Left Hand Lever Cap & Fixing Screw Saint M800/XT M760/M765
LD8501
10
XT ST-M760 Right Hand Top Cover & Fixing Screws XT ST-M760
LD8504
12
XT ST-M765, ST-M760 Left Hand Cable Cover XT ST-M760, M765
LD8506
12
XT ST-M765, ST-M760 Left Hand Bottom Cover Unit XT ST-M760, M765
LD8507
24
STM800/760-5 Right Hand Release Lever & Fixing Bolt Saint M800; XT M760,765
LD0926
XTR ST-M965 Right Hand Main Lever Assembly XTR ST-M965
LD0928
6
XTR ST-M965 Left Hand Main Lever Assembly XTR ST-M965
LD0930
7
XTR ST-M952 left Shift Pod XTR ST-M952
LD0931
10
XTR ST-M952 Rear Shifter Pod XTR ST-M952
LD0932
14
XTR ST-M952 left shift indicator XTR ST-M952
LD0933
20
XTR ST-M952 Right Indicator Unit XTR ST-M952
LD0942
50+
XTR ST/SL-M952 Derailleur Cable Adjuster Unit XTR ST-M952
LD0944
24
XTR SL-M952 left indicator unit XTR ST-M952
LD0945
20
XTR SL-M952 Right Indicator Unit XTR ST-M952
LD0953
XTR ST-M960 Right Side Main Lever Assembly XTR ST-M960
LD0954
5
XTR ST-M960 Left Side Main Lever Assembly XTR ST-M960
LD0991
10
XTR ST-M960, ST-M965 Right Side Indicator Unit XTR ST-M960,965
LD0992
13
XTR ST-M960, ST-M965 Left Side Indicator Unit XTR ST-M960,965
LD0993
19
XTR ST-M965 cable cover and fixing screw right ride XTR ST-M965
LD0994
22
XTR ST-M965 Cable Cover and Fixing Screw Left Side XTR ST-M965
LD0995
9
XTR ST-M965 Shifting Cable Adjusting Bolt Unit XTR ST-M965
LD0996
41
XTR ST-M965 Release Lever Unit Right Side XTR ST-M965
LD0997
22
XTR ST-M965 Release Lever Unit Left Side XTR ST-M965
LD5837
Discontinued
LX ST-M570 Rear 9spd Shifter Pod LX St-M570
LD5838
Discontinued
LX ST-M570 Left shift Indicator LX ST-M570
LD5865
7
LX SL-M570 Left Indicator Unit LX ST-M570
LD5866
50+
LX SL-M570 Right Indicator Unit LX ST-M570
LD6073
Alivio MC-12-c Left Indicator Unit Alivio MC-12
LD6624
31
XT/LX/STX-RC R/fireSL Shift Cable Adjuster XT St-M739,740; LX ST-M567; STX and STX-RC ST-MC34,36
LD8414
33
XT SL-M750 Left Indicator Unit XT ST-M750
LD8415
14
XT SL-M750 Right Indicator Unit XT ST-M750
LD8425
6
XT M750 Front Shifter Pod XT ST-M750
LD8426
20
XT M750 9spd right Shifter Pod XT ST-M750
LD8427
18
XT M750 Left shift Indicator XT ST-M750
LD6326
XT ST-M765 left hand top cover & fixing screws XT ST-M765
LD8505
12
XT ST-M765, ST-M760 Right Hand Bottom Cover Unit XT ST-M760, M765
BR2501
43
XT ST-M760 Brake Cable Adjusting Barrel XT ST-M760
LD6325
XT ST-M765 right hand top cover & fixing screws XT ST-M765
LD8502
13
XT ST-M760 Left Hand Top Cover & Fixing Screws XT ST-M760
LD8503
8
XT ST-M760/5 Right Hand Cable Cover XT ST-M760, M765
LD8344
Out of stock
XT ST-M765 Left Hand Main Lever Assembly XT ST-M765
LD8349
XT ST-M765 Right Hand Main Lever Assembly XT ST-M765
LD0999
Out of stock
XTR ST-M961
LD1000
8
XTR ST-M961
LD1002
Out of stock
XTR ST-M966
LD1003
XTR ST-M966
LD7007
10
Deore XT SLM751 Cable Adj Assembly XT SLM751
LD7009
Deore XT SLM751L Left Indicator Unit (Black)
