Different brake brands have pads with different surface areas. Looks like you're using your old Tektro rotors with the new Shimano calipers. I wouldn't expect the braking tracks to line up exactly.
As long as the pads are not overhanging the outer edge of the rotor, you'll be fine. If they are, then that's a problem. The angle on your front caliper picture makes it hard to tell, but it looks like the rear caliper probably is not overhanging.
