As long as the narrow Q factor and chain ring clearance will work, I don't see why not. You need to measure for that.
You will need the correct adapter and shims to convert the PF30 to the 68 mm wide by 24 mm spindle. Your front derailleur will need to be mounted high enough and you will need to play with the limit screws.
