1 - 6 of 6 Posts
· Registered
Can I mix and match ultegra r8000 and GRX crank arms? I know I CAN but is there a difference in offset on the non drive side? I've been googling for a bit now and can't find exactly what I'm looking for.
thx
· Registered
I use a 105 Stages PM left arm with my GRX crank. IIRC, the Q factor on the 105/Ultegra is 6mm narrower (3mm/side), so I put a few Wheels Mfg. spacers under the arm before installing. It doesn't make up the whole 3mm, but works great.
· Registered
I’ve got a 4iiii power meter 105 crank arm on my GRX 600 crankset with no spacers. Clears the frame by a couple mm. Works like a champ. If you have a GRX 800 crankset, the Ultegra crank arm will balance better because they are lighter.
1 - 6 of 6 Posts
