1 - 3 of 3 Posts
I have a SP dynamo hub and would like to purchase a spare connector. The Shimano connectors are much more readily available.
I've read that you can use a Shimano connector with a SP hub, it will just be a little tighter than the stock SP connector.
Does anyone have experience with this setup? Is it so much tighter that it's a PITA to dis/reconnect when removing the front wheel?
Thanks.
Interesting question. I've always thought they were interchangeable with no difference. But now that you mention it being tight, I'm pretty sure my light has a Shimano connector, and my hub is definitely Shutter Precision, and it is a tight fit. Sometimes it requires extra effort to remove the connector. Sometimes I just grab the pliers if they're close by. Sometimes I wedge a fingernail in there to get it started. And sometimes I think everything is put together properly, but my light isn't getting any power because I didn't push the connector on hard enough. But for all that, it's not a big deal. Now that I know that a SP connector would connect and disconnect more easily, it might be worth finding one if I were removing the front wheel daily, outside of my house, like if I locked the front wheel to the back or routinely put my bike in the trunk. As it is, I take that tire off once a week or so, and it's not a big deal at all. If Shimano's what you have, I would go for it.
viva la v-brakes!
I have two wheels, one SP, one Shimano. I’m not sure if my wiring is Shimano or B&M. In any event, it works with both hubs fine. I have noticed that it’s tight sometimes, now I know why. I can always get it off by hand, just takes a bit extra work.
Sent from my iPhone using Tapatalk Pro
1 - 3 of 3 Posts
