Shayne said:
... chainring bolt usually goes through both the outer and middle rings. There should be no teeth in the way of the nut on the backside.
Yes, the nut does have a long "sleeve" that fit's through the rings.
I've put the hex (bolt) on the outside, the nut (stupid shimano tool) on the inside.
When assembling the crank/rings (off the bike of course) & looking from the inside, all but the one hidden by the arm (Which has nut/bolt reversed from the others) has the middle rings teeth just enough in the way preventing using a screwdriver in the slot straight-on.
In the past, when I've used non shimano rings, some times the bolt will "go in" farther than
"normal", and the end/tip of the bolt goes past the end of the nut, preventing me from using a screwdriver at-all. Must use the shimano tool that I would describe the end like a cross, so the tip of the tool goes in the nut head-hole, and the sides reach down farther to catch the nut indents on the sides to hold while tightening.
There also is a difference between HG and IG rings, with a indent on the nut side to recess the head a bit, but a lot of non-shimano rings (even shimano's small) do not have the recess in the bolt-side...
