My problem is related to wandering bite point, but a bit different.
After the last bleed my XTR M-9000 rear brake works without wandering bite point like it should while riding, but if I squeeze the brake lever slowly it goes to the bar; whereas, when I squeeze the lever rapidly (just one squeeze & not the repeated squeezing to pump it up) the pads contact the rotor when the lever is half way to the bar (or where ever I adjust it to)
I had the stereotypical wandering bite point and did the brake bleed where you remove the caliper from the bike to hang vertical and removed the bleed screw completely and let the brake oil flow down from the funnel and out the caliper into a rag while rotating and tapping the caliper around in all directions. Finished off by bleeding normally and burping some more oil out after pads stepped and adjusted pad to rotor spacing.
I have used all bleed methods recommended including gravity bleed to hose attached to bottom bleed screw, syringe from the bottom, syringe from top and bottom, tapping, rotating, hanging etc.
When I burp the lever (attach oil filled funnel and squeeze lever to pump air bubbles out and nothing more) when the pads are partially worn, I get oil squirting out the bypass port in the lever and onto my grips, but the brake works after (either correctly or when pumped up for wandering bite point), so after the initial squirt there is not more oil loss.
I am wondering why the difference between slow vs fast squeeze.
I finished my ride about 4 hours ago and just now tested the lever again by first squeezing fast (it worked perfectly), but my second squeeze was slow and the lever went to the bar
Maybe the inside of the master cylinder is worn (almost 5 years old now) or burping the lever so that the bypass port was damaged?
Does anyone know of another reason?
