Need ideas. I'm completely stumped and pissed at my rear brake squeal. I've never had this problem with shimano brakes except when a caliper leaked. Braking power is fine, so I'm sure its not a leak. But I've checked for that 3 times now.
Brakes are xt 785 lever/xt 8000 caliper with shimano xt rotors . caliper is about a year old. All pads are metallic.
This all started with a simple pad change. A while back I purchased 2 sets of ice tech pads from a local guy and stashed them away. I installed one of the new sets about a month ago and on the 2nd ride with them I started getting a crazy squeal on long-ish descents. Checked the pads for oil, looked fine. Put a bleed block in the caliper and squeezed the lever about 40 times to see if any fluid was leaking. all good. I thought maybe I got some dud pads, so I swapped in the 2nd set from the guy and bedded them in on a hill near my house.
Next ride, same problem. It was driving me so crazy I swapped my front and rear rotors trailside. That didn't help.
Got home and noticed some play in my rear wheel. Took the hub apart and found that the main bearings had some lateral play, which wasn't surprising given the hub is at least 4 years old. Maybe there was some vibration at the hub that was causing the brake noise? Ordered new bearings, got everything back together and thought I had it licked. Next ride, same issue.
This week I bought a new galfer rotor and another set of metallic shimano pads. Just got done my ride and it's still doing it. I have a set of organic pads somewhere, and I'll try them out. But I know I won't like how they function, so thats not a long term option. (by the way, the galfer rotor isn't even close to round - crap quality!)
ANY IDEAS???
ANY IDEAS???
