Does anyone have the Shimano part # for a 203MM caliper adapter IS to IS for Fox 36 forks?
V VR46 · Mtbr minion Joined May 2, 2006 · 70 Posts Discussion Starter · #1 · Jan 22, 2007 Only show this user Does anyone have the Shimano part # for a 203MM caliper adapter IS to IS for Fox 36 forks?
R Rictrue · Registered Joined Jan 26, 2007 · 20 Posts #2 · Feb 26, 2007 Only show this user I am also interested in thsame info. Anyone?
W wogsman · Registered Joined Jan 10, 2007 · 1 Posts #3 · Feb 26, 2007 Only show this user Its SM-MA-R203S/S i got mine on www.chainreactioncycles.com part# 41262 i run it on the Pike 454 IS mount to XTR IS mount caliper with 203mm XT rotor.
crisillo · Super Moderator Joined Jul 3, 2004 · 20,810 Posts #4 · Feb 26, 2007 Only show this user wogsman got it! :thumbsup:
C CAO · Registered Joined Oct 4, 2004 · 497 Posts #5 · May 2, 2007 Only show this user hayes and magura adapters will also work with shimano calipers if you are having difficulty sourcing shimano adapters.
D dan0 · Vaginatarian Joined Oct 12, 2005 · 5,686 Posts #6 · May 4, 2007 Only show this user wogsman said: Its SM-MA-R203S/S i got mine on www.chainreactioncycles.com part# 41262 i run it on the Pike 454 IS mount to XTR IS mount caliper with 203mm XT rotor. Click to expand... that # is for the rear which will add 20mm in the front you need SM-MA-F203S/S
