Recently did a full bleed on my rear Shimano SLX M7000s using the Shimano funnel.
Ended up with a nice firm lever but not much power. Felt fine when you just spin the rear tire but when riding there is no power. Can't even lock up the rear wheel.
So was getting ready to do another bleed and noticed the little o-ring on the bottom of the funnel was missing. UH OH!
Looked everywhere for it and can't find it. I always store the funnel on its little stand and its no where to be found.
I am now fearing when I last removed the funnel from the brake lever the o-ring stuck to the inside of the bleed port.
Then I put the bleeder cap back in and possibly forced the funnel o-ring inside the master cylinder. Although I didn't notice the bleed cap screw going in wonky or needing extra force to seat.
Do you guys think this is even possible? Seeing how I am missing the funnel o-ring and my brakes are way down on power now I just assumed this is what happened. That o-ring is quite tiny.
Is it possible to open up the master cylinder somehow, to see if its inside?
There is that round looking end cap that looks like you could unscrew it with needle nose plier tips.
Couldn't find any vids on master cylinder disassembly.
Appreciate any thoughts.
