Moustache rider said:
Rust is only a problem when bearings are inadequately lubricated.
Making them out of stainless may save you from corrosion which will show up first, but they will die from accelerated wear soon anyways so it doesn't really matter.
Bearings will better seals or an external zerk so they can be easily greased would be more interesting to me.
The reason for offering stainless is simple, the vast majority of the bearings I replace have corroded, not worn. For those actually wearing bearings out in the dry (the small minority), we already have a range of suitable bearing replacements.
The problem is, water gets into BB's and sits against the seal where it causes corrosion until it gets inside. Water is heavier than grease and once inside the bearing is doomed.
"Better seals" aren't an option due to a lack of space.
A stainless bearing gives you a much wider time-frame to get in, clean the water and contaminated grease out and re-grease.
An external zerk requires redesign or extensive modification of the BB cup. I can offer that already but the price doesn't stack up well against other options, like straight bearing replacement or bearing upgrades.
The other problem with a zerk to push more grease in is the water being heavier remains.
I do offer CNC storm drains cut into BB cups, both as an upgrade and as an option on new bottom brackets.
But it's not a DIY option that can be fitted in an evening in a garage workshop to your existing BB, where stainless bearings are.
