I have Shimano shifters... and I want to get a Sram X.O.
Will that work?
Will that work?
Nope. SRAM uses 1:1 cable ratio while Shimano uses 2:1Purple Liquid said:I have Shimano shifters... and I want to get a Sram X.O.
Will that work?
Its funny you mention that, I just busted a sram 9spd chain (not sure what model, about $ 30 @ lbs) when i was on my lower front chain ring and 32 cog in the back. its a used cassette so it might have been that but I was pushing semi hard.danielhaden said:Chances are that if a Deore LX rear derailleur won't do an absolutely perfect job with 7, 8, or 9 speed Shimano shifters, then there is something wrong with:
Shifters
Cassette
Derailleur hanger
Chain
Chainring
Problem solvers:
While a new Shimano chain works great an a new Shimano cassette, after the cassette becomes worn, an SRAM chain will work better. This is one of the very rare cases where a "mixmatch" is a good idea.
It is highly likely to need to replace the rear cassette whenever replacing a worn out chain.
LX cassettes work very well,
the XT 11-32 is a loser but the rest are very nice,
and the XTR 11-32 cassette is just fine.
SRAM cassettes only work very well with SRAM rear deraillers, chains and shifters (although you may use Deore front derailleur, which works better than any of SRAMs). Yes, they are "Shimano compatible" cassettes, but since they are not hyperglide, the very fine performance only comes with using matched parts.
An SRAM system is an inexpensive way to remove some weight from your bike, if replacing Deore or lower components.
In many cases, it is wise to replace the middle front chainring or whichever you use most, and re-torque the bottom bracket; and this is especially true when replacing a chain that was very worn. This is just part of regular maintenance.
When considering upgrades:
A caution about the 9 speed chain. . . There is no 9 speed chain strong enough to withstand a rider seriously sprinting a 24 tooth chainring with a 32 tooth gear on back. For high-strength application, use the 8 speed chains. In my opinion, the 9 speed chain is unsuitable for mountain bike application.
An 8 speed chain on a 9 speed cassette?bob46802 said:Its funny you mention that, I just busted a sram 9spd chain (not sure what model, about $ 30 @ lbs) when i was on my lower front chain ring and 32 cog in the back. its a used cassette so it might have been that but I was pushing semi hard.
i will look into getting an 8sp chain.
I really don't know what he wanted to say, but using an 8 speed chain on a 9 speed set up does not seem like a good idea. There is a reason why they make 9 speed chains, you know? that reason being that to squeeze 9 cogs where they used to have only 8 they had to space them closer. The problem with that is that the space where the cahin fits got smaller, so they needed a thinner chain. See where I'm going? I'm sure somebody around here has tried an 8 speed chain on a 9 speed set up, but, it just seem like a bad idea. Like I said, there is a reason they make 9 speed chains. And that reason is not only because they break more often.bob46802 said:maybe I dont understand what daniel haden was saying then. im new to upgrading parts on my bike so i have a lot to learn.
Sram cassettes will work fine on any derrailleur as will shimano. The chain used is the only thing that will have a direct influence on a cassettes performance. A derailleur only needs to move 4.35mm to accomplish a shift in a 9 speed system. 4.35mm is 4.35mm regardless if a Shimano or Sram derrailleur moved the chain that distance.danielhaden said:SRAM cassettes only work very well with SRAM rear deraillers, chains and shifters (although you may use Deore front derailleur, which works better than any of SRAMs). Yes, they are "Shimano compatible" cassettes, but since they are not hyperglide, the very fine performance only comes with using matched parts.
Simple answer, NO.Purple Liquid said:I have Shimano shifters... and I want to get a Sram X.O.
Will that work?
