I most likely should replace the acera but I want to see if it is even worth adjusting if there are anyadjustments to make.
The problem is: When I shift from 6th to 5th or from 5th to 4th the rear derailleur seems to get caught. It will not shift to 5th gear or if I am in 5th it will not shift down to 4th unless I tap on the derailleur or hit a bump as I am riding. The shifters indicate that I am in 4th or
5th but the bike is actually in 5th or 6th depending which gear I am shifting from. Is there anything I can do to adjust this problem or should I just replace the derailleur? Keep in mind this is a new bike wth all new components on it. I dont want to replace anything yet but if I have to, well then I have to.
