1 - 7 of 7 Posts
Discussion Starter #1
Is it good idea to use shim? Would the shim cause play in dropper post?
Sent from my SM-G965W using Tapatalk
Shim your butthole, fix your plumbing problems.
Sent from my moto g(6) forge using Tapatalk
I have has issues with a 30.9 to 31.6. Seems it's so close in size that the lower end of the post can wiggle a bit down in the frame and touch the inner wall. This may result in "groaning" or "Moaning" noises...Is it hot in here?....seriously, I took another shim and cut the upper lip off and put two (2) shims on the post. Problem solved.
Discussion Starter #6
Really. Do shims of this size wiggle?
1 - 7 of 7 Posts
