try this...
Hope it helps, good luck
-Que?
I've had the same problem with LX shifters before too. What worked best for me, as suggested by someone from around here, was to put a few drops of chain lube in the shifter assembly. I removed the little plastic screw that covers the cable insertion port and squirted in a reasonably liberal amount of Boeshield (a chain lube). After working the shifter through its full range a few times, everything seemed to be back to normal.sundeep said:
-Que?
