Seeing some of the other clunker builds recently, I'm finally getting around to posting my own here. The frame is a 1936 Shelby Traveler that I got from a local shop that specializes in old ballooners and Krates. It was mostly complete with fenders, rack, and everything but the saddle and chain ring apparently original, but as you can see the patina is "extensive" and restoring it to show condition would have been a huge project. Aside from this frame I had the choice of a couple of pre-war Schwinns and a Colson, but this one was the largest (I'm 6'2") and seemed as well made as any of the others. I recently found out that Gary Fisher's first clunker was a Shelby Traveler (according to Joe Breeze), so at least I know it's a legit choice
I'm using Alan Bond's advice and guidelines on the "proper" way to build a clunker like the kind he built in the 70's and trying to make it as close to period correct as possible, though there are a few things I had to compromise on. Anyway, on to the pictures. I'll explain what's going on as I post them, starting at the beginning which was back in April.
Here is how it sat on the showroom floor when I picked it up.
I took it back to my shop and stripped it down to the bare frame. It was in surprisingly good condition internally, very little rust and just some sand and dirt in the BB shell that fell right out. I wanted to use a cartridge BB for the sake of simplicity, so I installed an AC BB adapter to use a Shimano UN71 68 x 128 BB. The front derailleur is a Suntour "Spirt", which is not a typo, I assume it's Engrish for Spirit. This is a "top normal" derailleur, meaning when the cable is slack it sits to the outside. I'll explain why I chose this when I get to the shifters. Also, I managed to find one with a 22.2mm clamp, so I don't need to shim it to fit the seat tube.
The rear derailleur is a Suntour Cyclone, which was Alan's first choice when he was building these 35 years ago. I had the derailleur tab brazed on by my friend Greg at CyclArt, and he also re-spaced the rear triangle to 135mm and aligned it.
The hubs are Union drum (or expander) brakes, the finest made at the time and rarer than Unicorn poop, especially the fronts. Got lucky and found three of them (2 RR, 1 FR), hopefully to be built into wheels this week.
To be continued...
To be continued...
