1 - 5 of 5 Posts
Thread Killer
has this ever been done before? you take a standard, knobby tire, and pretty much attack it with a razor knife or some other instrument of cutting...they do it with monster trucks, to give the tires more grip...so i'm thinking, maybe doing this to a mtb tire would add a little mroe grip, while cutting out some weight from the wheels. OR, shaving the treads off completely to make a smooth road tire.
eh...would either of those work?
some kind of hero...
You can cut, sipe, carve or grind/shave... best have some idea of what you want to gain before starting because the tire can be pretty much scrap if you're not careful. This is a real art when it's done well. Google it and you'll see lots of info - mostly for cars, dirt track and off road. Shaving/grinding used to be the rage for street car tires...
Cheers
:cool:
Thread Killer
Discussion Starter · #3 ·
i'm looking around online about shaving bike tires...would i want to shave just the center, and leave the shoulders of the tires for grip, or could i get the same amount of grip with shaving the shoulders?
i'm kinda trying to convert my $8 goodyear MTB tires into road tires, btw
Check this out...
http://forums.mtbr.com/showthread.php?t=383804&highlight=clearance
If this is for the road, shave the whole tire down to the radius you want. You probably don't want a square section tire - thats what you'd get if you only shaved the center...
Good luck
:cool:
Thread Killer
Discussion Starter · #5 ·
airman said:
Check this out...
Good luck
:cool:
sweet! that's exactly the same idea that i had, i just didn't know if anyone had posted that up...i did search "tire shav*" and nothing came up.
1 - 5 of 5 Posts
