1 - 7 of 7 Posts
Discussion Starter · #4 ·
hi,
this is the complet bike:
9kg560
with pedals/computer/noTubes/bar-ends
(and heavy stem/shims/ti-bar)
ToDo
stem needs to be changed (2cm to long, and lower angle)
MightDo
rotor stem
rotor 2Xcranck
crankbro 4Ti
easton bar without bar/ends
pic doesn't do the bike justice, it seems cramped
bought most of it new,
driveline+cockpit from old bike
if i had to do it again: 80mm fork in stead of 100mm, suits this "small" frame better
Discussion Starter · #6 ·
yep, seven ti is on its way
I used the bike on the Grand Raid Cristalp (Swiss) and it performed greatly,
only the oil of the fork heated up and the fork performed poorly for a while,
afterwards the oil cooled down it functioned normally
(as it does today)
the bike is as agile and stable as it felt on the first rides
glad i bought it, it's definitly worth it
Seven Sola Pic and question
I like your Gold! Question: What is your height and inseam, and what stem did you end up with?
I am dealing with dom fit issues now.
Note: Saddle has been swapped out and moved foward since this pic
1 - 7 of 7 Posts
