I just ordered two Paragon Machine Works MS1018 304 stainless steel bosses. They will be installed on a steel (not chro-mo) 3 wheeler frame, I already drilled the 1/4" holes.
Per the part description I noticed that the filler material is part of the boss. This will be my first time installing these, curious what you might recommend for inverter TIG settings to weld them? Specifically I use an Invertig 221 and 20 series torch.
I'm thinking about using a 1/16" 2% Lanthanated tungsten, no filler rod per the part description, 100% AR at ~20cfh, but about what amperage would you recommend?
Other settings above sound OK?
I don't braze or solder, so TIG is the only option for me.
