It's a 2005 36 TALAS RC2 fork. I weigh about 120-122# and have 40psi in the TALAS chamber. Manual says <125# should have 45psi and when I called FOX they recommended no lower than 40 psi.
The question is: do I measure sag on the fork when I'm in normal riding position or when I have my upper body weight learning over the bars and am standing up on my pedals? When it's the former I seem to have way too little sag per the manual recommendations, but when it's the latter I seem to have more luck getting close to the recommended. Or do I just say, 'forget the manual,' pump the fork pressure up/down depending on whether or not I get full travel?
MANUAL says (for 150mm travel mode):
Freeride Plush sag- 38mm, but I'm not coming close (unless my body weight is over the bars) as you can see by actual the measurements.
Acutal sag (normal riding position) 15mm @ 40psi (from the fork seal to the bottom of my zip time on the stanchion)
Actual sag (weight over bars) 32mm @ 40psi (from the fork seal to the bottom of my zip time on the stanchion)
I have a feeling you measure sag when you're in a normal riding position, but if so, what's up with my fork (why am I not even close to recommended sag?)
Thanks.
Thanks.
