Sure like mine. I just finished taking off the paint as I want to go the raw aluminun look. The frame is pin straight, very nice welds and has 4 bearings in the swing arm. The seat tube has scared some away but it is nice that the seat goes foward as you lower it if you use a GD or similar. Make sure the seat clamp on your seat post will tilt enough to suit you. Check the geometry to make sure it is what you want in a bike. 7.5lbs is the actual weight with shock and headset. With an AD-12 shock I get almost 5 inches travel. Some will say it is overbuilt. Thats why I like it. I'm 5-7, 30 inseam 180lbs and a 17" is almost too small. Some of the fasteners on the linkage are alittle too short, I removed the smooth washers to get another thread deeper.
