Sure, tons.
Raceface Diabolus, Easton EA series, and the Salsa Shaft all come to mind, and each of them gets you around 20mm +/- of setback. Truvativ Team gets you 10mm. Thomson is only good for about 16mm. The Titec El Norte is pretty extreme, probably more than you want.
Also look into swapping saddles. Not knowing what you use, just as an example I can tell you that two saddles I find very similar feeling -- the Terry Fly and the WTB Rocket V -- have distinctly different rail designs that allow the Terry to sit farther forward on any given post (or, oppositely, the WTB to sit farther back on any given post). Definitely worth you checking out some other saddles to see what might get your saddle where you want it.
BTW, does "correctly fitted" mean a pro fit from a bike shop? Just curious, because the first aspect of fit is your saddle relation to the cranks. Normally any cockpit adjustments follow behind saddle position. Not that there is anything wrong with experimenting with different positions, of course!
