1 - 11 of 11 Posts
FIRENZE rulez !!
my lever , when fork is locked , is touching the bar
possible to fix it ?
i pull off red rebound dial with 1,5mm allen key
i pull off 10mm upper bolt
i remove the blue lockout lever
then ?
how can i do to make the red rebound splinde turning counter clok wise of 15-20° ?
must i remove lower 10mm nut ?
try to turn the spindle , it's hard :eek: ... don't want to broke something .
help !! :madman:
unemployed team mechanic
yes i know. when you loosen the outer collar you can spin the lockout lever and have it positioned wherever you want it (spinning the damper shaft in the oil cylinder). Then you tighten the collar back down. its that simple,
FIRENZE rulez !!
Discussion Starter · #7 ·
okkkkkk well.
thank for help
i will do in a few hours !!!
for my safety , i discharge first all air inside my lefty. maybe not necessary but a safer way of work .
in helicopter's world: safety first
Fixin' shocks Day & Night
Yeah Capt. Pabst is right, you don't need to let the air out. It will make it a bit easier to turn the lever to where you want it. He is also right about the tool, a Shimano outboard bearing bottom bracket wrench is the tool you need Shimano part # TL-FC32, you will need to loosen the top cap of the fork and turn the lever. You will also need to do the steps you have done and remove the damper knob and lockout lever other wise you cannot remove the top cap if that is what you wish to do. You also could leave the damper knob on and the lockout lever in place and loosen the top cap then rotate the lever to the desired postion, then tight the top cap back down.
1 - 11 of 11 Posts
