So i going to service my rockshox tora 302 fork on my rockhopper tomorrow and been looking at all the guides/manuals
Problem is there so many and many have different views on how to do it i need some advice from those who have done service with simular fork.
questions:-
Is it worth removing the lower leg seal+Foam rings?
And if not can i spray isopropyl alcohol/degreaser into the lower legswith the seal+foam ring still inside without worry as manual seems to says?
If i do remove the lower leg seal/foam ring, can it be done this way,Part 4-8.??
(http://www.bikemagic.com/maintenance/simple-fork-servicing/3253.html)
Ie without needing a "special seal insertion tool"
That all, i know where to put grease ie springs/seals and only small amounts
cheers if anyone can help
questions:-
