1 - 4 of 4 Posts
I've been riding my Reba Team Dual Air for about 10 hours and the suspension doesnt work properly.
The fork is set at 100mm but it only uses 35mm of travel.
I let out all the air from the negativ and positive chamber and pushed it downward to see how much travel I got and it only goes down 35mm.
There is a distinctive stop after 35mm like there is something solid in the way.
What can I do? Should I disassemble the fork and take a look?
Have the same thing
I had the same thing. It stopped at about 40mm in 85 mm setting, with all air removed from the + chamber. Checked the oilheight in the damper assambly, was ok... Sent it back to the lbs, they sent it to the distributor, got it back 2 weeks later and it wouldnt go down any further than 60mm!
Now it is back again to the distributor. I repost when the fork is back!!
If the fork had been out of warrenty, i would check myself. It should not be too hard.
Same thing with Reba SL
Hi,
I had the same problem you had with my Reba SL U-Turn. When I would push down on the fork (all air out), it would only move from the 85mm mark to the 115mm mark. i would hear a "clonk" at the bottom of the travel and also when it got back up.
I got my brother to look at it and we did manage to push it down further to use all of it's travel. That was after fiddling a bit with the travel adjustment knob. I guess it only needed a good push.
I did end up sending it to the distributor because it also wasn't getting any sag. The negative was also not keeping more than 50psi.
I got it back last week, seems to work just fine now. My mistake was not asking exactly what was wrong in the first place. Sory I can't help yo umore than that.
1 - 4 of 4 Posts
